How to remove old tight deck screws?
Old 10-13-05, 05:19 PM
I'm dismantling a deck and don't want to ruin the redwood decking, still in good shape. Some of the screws are coming out, and a lot aren't. They are tight enought so that the screwdriver bit slips in the phillips screw slot. If I can get a horizontal visegrip on the head I can often get the screw out, but many won't even come out enough for that.
Are there any tricks for accomplishing this. I hate to get out the crowbar...!
John
Old 10-13-05, 07:29 PM
Received 170 Votes on 151 Posts
In my tool box I have a type of screw driver [wish I knew the name of it] that is designed to be hit with a hammer and turns the bit as you hit it. I have had moderate success using it on stubborn screws. Now if we only knew what it is called....
Old 10-13-05, 07:53 PM
It's called an impact screwdriver...I'll see if I still have one and if so give it a try. But it the phillips slots aren't holding I'm not sure any kind of screwdriver will work, if the slots would hold I could get the screws out.
John
Old 10-13-05, 07:58 PM
EZ out bolt exractor and a reverse thread bit
Reverse drill bit makes a hole, then a reverse thread extractor is tapped in, usually held by a tap and the whole thing is twisted out
I use a kit, but you can get just one size of bit and EZ out at the hardware store
Old 10-13-05, 08:03 PM
mmmm...sorry, did a search for bolt extaractor, you want a screw extractor
http://www.doityourself.com/store/sc...ractorsets.htm
Old 10-13-05, 08:05 PM
This one's sort of like my kit
http://www.doityourself.com/store/6717235.htm
Old 10-14-05, 07:05 AM
One of the reasons impact screwdrivers work is you are forcing the bit into the head helping it to grip better. It is a little simpler than drilling and using an extractor but you will likely have to drill the real stubborn ones.
Old 10-14-05, 08:37 AM
rdhamm's Avatar
Sawzall?
Can you get beneath the deck and use a bi-metal blade and cut between the bottom of the deck board and the joist?
Old 10-15-05, 02:19 AM
The decking is on real tight and since it is next to an abandoned house(soon to be bulldozed) there is no electricity available even if I could get a bimetal blade to fit. I'm going to look at impact screwdrivers and see how well they work.
John
Old 11-20-05, 08:26 AM
COREY HALLBERG
Battery Operated
There A Reletively Cheap Battery Operated Sawsalls Although I Wouldnt Recomend Them For Commecial Use But For A Small Project Theyre Ok But Id Try The Impact Driver First.
Old 01-13-06, 10:29 AM
an old aircraft mechanic's trick: get some Clover valve grinding compound. Dip the tip of your screwdriver in it before trying. the phillips will grip much better.
