SDS Screw
SDS Screw
I read somewhere about an SDS screw. These apparently are used for attaching ledger boards for decks insstead of lags.
What exactly are they?
What does SDS stand for?
Where can I get them?
Thanks.
Thanks.
rdhamm,
All answers here,
http://www.strongtie.com/products/co...rs/screws.html
Any major lumber yard, possibly a bix store.
Hope this helps!
All answers here,
Hope this helps!
Thanks Doug
I'm a bit confused. It seems that SDS is a trade name by Simpson.
I'm not sure, but do codes often refer to manufacturer specific items? That seems odd to me.
Perhaps I am wrong and SDS is a generic name, like 'lag'.
rdhamm,
It is a Simpson Screw - Strong Driver - That is what they use for their abbreviations on products.
It looks like a lag and performs like a lag screw. No difference.
Hope this helps!
Hope this helps!
Received 0 Votes
Hope it's OK to add one more thought here. The main difference in SDS screws and lags is that the SDS don't need to be pre-drilled. Apparently, this is why some counties are requiring them now and not accepting lags....guess too many lags were being improperly pre-drilled, or not drilled at all.
The shear strength of an SDS is about double that of a common lag bolt. That, and improper predrilling is why many counties are not allowing lag bolts to attach a ledger board. I happen to be in one of the first counties that refused to recognize lag bolts. If I attach a deck via a ledger board, I almost alway have to thru-bolt it. Therefore, I do mostly free-standing decks. And a free-standing deck will NEVER result in a hole in the siding that water or moisture can enter into and rot the framing of the house.
