How long to dry before priming?
Old 02-25-06, 06:36 PM
W
How long do I need to let rain wet wood (PT 2x4s) dry before priming with oil-based primer? Thanks as always
Tom
Old 02-25-06, 06:46 PM
Received 321 Votes on 285 Posts
All wood needs to be good and dry before applying oil base primer/stain/paint. Without a moisture meter I usually look at the color of the wood, if there is any darkness [from moisture] let it dry another day.
Is there a reason you are using paint instead of stain? Stain usually doesn't require a primer. Paint does give better protection than stain but is apt to peel as it ages, stain just wears away. Restaining can be a lot easier than scraping, priming and repainting.
Old 02-25-06, 06:52 PM
W
We chose paint for a few reasons; to try and match the concrete walls, and because there are a bunch of steel brackets in the structure.
Any shot 24 hours would be enough drying? I was thinking not but someone said yes so I figured I should ask you guys just in case. Schedule wise it would be great to do it Sunday....
Old 02-25-06, 06:57 PM
I understand about the paint - it is a shame we can't always do things the easy way
How long to let it dry will depend a lot on the sun, wind and weather conditions in general. If there is any doubt about the wood being wet - don't paint. If the moisture gets sealed in the wood it will find a way out - usually through the paint in the form of peeling
Old 02-25-06, 07:11 PM
W
Yea, its been pretty sunny with some wind today, about 80. We'll see what it looks like tomorrow. If in doubt, put it off. Thanks Mark!
Tom
