Sanding deck after power washing
Old 05-08-08, 01:18 PM
H
I powerwashed my deck and I want to sand down the rough spots now before sealing it. What grit of sandpaper should I use? The deck is pressure treated pine...Also, what tool can I use to speed up the process? Belt sander? I have a small handheld orbital sander but I'm afraid that will scratch the wood since it wouldn't be going with the grain.
Old 05-08-08, 01:44 PM
R
I am in the process of doing the same. I started to use an orbital with 80 grit, then switched to a belt sander also with 80grit. Did a much better job. A bit hard on the knees. Knee pads would help.
Old 05-08-08, 03:50 PM
H
I have an orbital sander...would have to buy the belt sander.
The orbital didn't scratch the wood?
Old 05-08-08, 05:30 PM
Received 359 Votes on 316 Posts
I doubt the orbital sander would noticably scratch the wood but if it does, switch or finish up with a finer grit. The stain should hide any minor sanding scratches.
When a deck is cleaned properly there shouldn't be a need for sanding. Raised grain is often caused by either too strong of a bleach solution [which damages wood fibers] or too much pressure was used ie; wrong tip or tip too close to the wood..... just so you know, so it will be easier next time
Old 05-08-08, 05:58 PM
L
hurricanefloyd,
How big is the deck?
An orbital sander (or a random orbit would be better) will work fine on a small deck, but if it's very large, I would rent a floor sander and get it done quicker and without causing knee problems.
And treated pine -- definitely wear a mask!
Old 05-08-08, 06:04 PM
I agree a floor sander would be quicker but you need to make double sure all the nails/screws are countersunk!!
Old 05-08-08, 07:57 PM
H
it was definitely too much pressure, too close to the wood. the deck isn't huge...maybe 20x10 or close to that.
Old 05-09-08, 03:25 PM
Received 97 Votes on 85 Posts
A deck shouldn't be overly smooth to seal, I use 36 grit if I have a lot to remove, but finish with 100 grit.
