Can I "glue" pressure treated deck boards?
Old 08-20-08, 08:03 PM
As I asked about in another thread I plan to use hidden fastener system. There will be a few places too tight or impossible to use the hidden fastener due to the decking pattern Id like to use.
Is it reasonable to glue down pressure treated deck boards in a few spots or will this not last?
Old 08-21-08, 04:26 AM
the_tow_guy's Avatar
Received 146 Votes on 114 Posts
Interesting question. With the expansion and contraction of the deck boards I rather suspect gluing would not be advisable.
What say you pro carpenters?
Old 08-21-08, 04:58 AM
W
Received 51 Votes on 46 Posts
Deck Boards
Gluing would not be sufficient for me. What about "toenailing" with screws from the underside? Do you have access to the underside?
Old 08-21-08, 05:20 AM
I do have access to the underside, but toenailing wouldnt really work due to the extra joists I have in this spot. Id only be able to secure one side of the length of the board.
Old 08-21-08, 03:21 PM
Received 1,165 Votes on 1,123 Posts
Try the glue. What's the worst that can happen - it doesn't work and you have to drive a couple screws?
Old 08-21-08, 03:36 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Have you thought about drilling and coutersinking, then installing a glued plug in the hole? You could do that all around and it would be symmetrical.
