Deck cleaner
Old 05-06-09, 08:21 AM
R
Deck cleaner
I am still looking for a product to clean my deck. I have got some cleaning solution from the local hardware store but am very disappointed with it. Just using my pressure washer did as good. Any suggestions?
Last edited by the_tow_guy; 05-06-09 at 12:29 PM. Reason: No company/product bashing
Old 05-06-09, 12:28 PM
the_tow_guy's Avatar
Received 59 Votes on 49 Posts
When we had a deck I liked Wolman's:
DeckBrite Wood Deck Cleaner
Old 05-06-09, 01:49 PM
Received 330 Votes on 293 Posts
Did you use the correct product according to the directions?
What are you needing to clean off of the deck?
Here in the S.E. mildew is the main problem so I usually just use bleach [mixed 50/50 with water. I'll wet the deck and then spray on the bleach/water solution with a pump up garden sprayer, let it set but not dry and then rinse with the PWer. Stubborn spots can be taken care of with a 2nd application and/or maybe a little scrubbing.
almost forgot
Welcome to the forums!
Old 05-17-09, 04:15 PM
T
Hi,
I am also looking for a deck cleaner. I have a composite deck (moved to our first home a few months ago) and on advise of a friend nearly bought a pressure washer to clean it (1800 psi 1.4 gpm). However, after reading the posts here, I realized that pressure washing the deck is not really a good idea.
Our deck has mildew and mold (pollen is clearly visble).
Any suggestion on which deck cleaner is best for composite decks? One I found is "Expert Chemical Composite Deck Cleaner and Enhancer" (local Home depot).
Thanks
Old 05-18-09, 05:44 AM
Well, if you look at the label you'll find the active ingredient is Sodium Hypochlorite - common bleach - so $18 for a gallon of bleach sounds pretty expensive.
