50/50 chlorine bleach for deck??
Old 04-12-10, 08:53 AM
R
Question 50/50 chlorine bleach for deck??
I just used Olympic Premium Deck Cleaner‎ which works great. I believe the Bleach is what is making it work so great (seeing its all I can smell!)
I need to finish the cleaning the deck today and I ran out of the Olympic .
Can I use a 50/50 mix of cheepo Chlorine bleach ( or does Olympic use oxygenated Bleach??) Is this gonna yield similar results and save me some money?
Old 04-12-10, 01:51 PM
Received 674 Votes on 597 Posts
I can't say for sure if regular bleach will give the same results but for the most part, bleach is what I use to clean decks, siding and such before painting/staining. Bleach can destroy wood fibers and harm vegetation! You never want to use it stronger than 50/50! You'll need to rinse well, including any vegetation that might get run off or misted with the bleach. Wetting those areas first [and during] will help to dilute any bleach that gets on them.
What type of stain do you intend to use after the deck is clean and dry?
Old 04-12-10, 02:14 PM
R
Hi, thanks for the reply.
I actually had to get this done so I can stain next weekend. I ended up using a little less then a 50/50 bleach solution and it worked great!
I rinsed the deck as best i could with a garden hose went over the whole deck about 4 times with the bleach and rinse.
I am trying to decide on a solid, semi trans or semi solid.
I Posted a thread for suggestions here:
http://forum.doityourself.com/decks-...ml#post1716617
I would really like to go with semi trans but I am not sure if my deck is in good enough condition to yield the results I am after.
Before:
After:
Old 04-12-10, 02:36 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
Just an opinion...but I think you should use a semi-trans...looks like the wood cleaned up pretty well, and the semi would allow the grain to show a bit. Of course it won't wear quite as well...but on the walking surfaces....I think it lasts longer than a solid.
I just never liked the solid stain...so I'm biased I guess.
Old 04-12-10, 02:40 PM
R
Thanks Gunguy
Some opinions is exactly what I wanted to hear
Old 04-12-10, 02:49 PM
It's a little hard to say until the deck is completely dry. If the wood color is fairly consistent, you should be ok with a semi-transparent stain.
