Deck Footings Not Level
Hi - just poured 6 footings that will accept 2 beams for a ground level deck (no posts being used). I did a dry fit of the beam and it looks like one of the six footings is slightly higher than the others, which are all level. This one footing is about 3/4 of an inch unlevel over 4 feet doesn't sound like much, but I'm spanning the 3 footing with a continuous 20' beam, so I'm anticipate it causing me problems.
One option I thought of is raising the other 5 to match, but I'd rather not do that. The only other thing I can think of is to notch the beam at the higher footing so it actually sits down level with the other 2 footings in the row.
Like I said, the footings are 20' long doubled 2x8s. Is notching in this way even possible. I haven't actually figured out how much of a notch it would have to be, but I'm figurin git would be slight.
Are there any other methods to fix this? HELP! Thanks!
Temporarily Suspended
Another option is to chop some of the footing with a cement chisel & a small sledge. Make sure all footings are sloped from the center downwards to the edge, so water doesn't collect.
Another option would be to work off of the footing that is high and post (or shim) the other 5 footings as needed to bring the beams to the desired level. Raising the deck 3/4" probably isn't going to matter, and it will certainly be easier.
