advice on re-staining a deck
Old 05-27-10, 01:42 PM
V
I bought a house with a very large deck that needs re-staining. The existing stain is flaking down to the bare wood...pretty unsightly. It's a solid color stain. I guess i have to remove all of it before re-staining...would I use a paint stripper?...would I sand?...should I just reface and save the headache>
Deck is approx 20' x 60'
thanks in advance
Old 05-29-10, 06:29 AM
fewalt's Avatar
Try/test strippers first. Deck stripper or paint stripper.
very caustic - follow label warnings!!
sanding is an option.
fred
Old 05-29-10, 10:59 AM
Received 741 Upvotes on 647 Posts
Most of the time, a good deck cleaner and a pressure washer will remove all the failing stain. I wouldn't bother with using any paint stripper - it shouldn't be needed.
Old 05-29-10, 06:26 PM
fewalt's Avatar
Generally, stains do not flake.
Some solid colors stains may flake, and it will be very similar to a painted surface.
My commercial p/w would have a problem removing a solid stain/paint.
But it is worth a try before any caustics would be needed.
fred
Old 05-30-10, 04:15 AM
V
thanks to all...will try the pressure washer first!
