Gap in new porch posts.
Just replaced back porch columns with treated 6x6s on pavers. I'd like to attach a picture of the problem, but I don't have that permission.
The concrete slab of the back porch slopes obviously for run-off. I underestimated the forward slope of the porch slab in cutting the base of the 6x6, and therefore the front paver is loose. How best to secure it? Construction adhesive then caulk....shims...?
The 6x6 and aft paver are solid.
Thank you.
--Bryant
Thank you.
--Bryant
A picture is worth 1,000 words. You have to upload your picture to a hosting site like photobucket.
http://forum.doityourself.com/electr...your-post.html
Posted pictures.
marksr, the link is clearly on my last immediately below yours...?
wirepuller, the posts are in there, tight as skin on a catfish, at least at the aft paver. And at the top, equally tight; I mean they're not moving. That front paver is not totally "free", but it can be bumped out of place. I'd just like recommendations on how best to secure that front paver. ??
Frustrating, I know.
Hi, Mark...no the posts were plenty long. I stood them on the concrete floor of the porch, marked, squared and cut. A nice tight fit that was appropriately forced into position, with the posts riding on the pavers as I did so. But when in position, the slope of the front edge of the porch floor caused the front paver to be a bit loose.
My inexperienced thoughts are to shim it tightly with metal shims (prevent rot as with wood shims?) and then caulk the base.
You want a mechancial method to attach the post to the slab. You don't want just gravity to hold the bottom inplace. It needs brackets of some type screwed into both the post and the slab. You wouldn't want something to hit the bottom of the post and moving it out of position
Mark, thanks. The posts are not load bearing in any capacity. The previous posts were decorative prefab wood on 5x5 metal cleat bases; then toenailed on top with finishing nails. It'd take a dang hard blow to knock these 6x6s out of place.
My easiest thought is to just bond them to the slab with a premium adhesive and let them live peacefully.
More wild creative thinking is that I can metalsmith; and I just might try to slide some thin handmade steel shims; but it's tight (>1/16"). If the paver busts from pushing the shims in, I can replace the front two and try something else.
Or!!! I could sell the house!!!
