installing a ledger board
Old 08-27-10, 02:01 PM
B
I have removed the old deck and all of the T111 siding behind the ledger board has rotted because it was never flashed and sealed. My question is this should i replace the T111 and attach the new Ledger board or can i attach the ledger board directly to the rim joist and studs.
Old 08-27-10, 04:54 PM
chandler's Avatar
Received 4 Votes on 4 Posts
The original ledger should have been attached to the house rim, anyway. Cut away any damaged wood and attach your ledger using 1/2" HDG carriage bolts, the apply flashing from under your siding to over the ledger and out over the joists slightly.
Old 08-27-10, 07:13 PM
G
Old 08-27-10, 07:48 PM
P
Temporarily Suspended
Build the new deck free standing. You don't need a ledger board at all.
Old 08-28-10, 04:39 AM
chandler's Avatar
With free standing, you could make repairs to the siding and call it a day, as Pulpo said.
Old 08-28-10, 12:25 PM
G
Check with your local B.D. on free-standing. You may have to set the new piers within 5' of the house as deep as the basement footing. OR, at least below the frost line for your area if a crawl space foundation. Some accept the small pier blocks, check and see.
Gary
