remove sealer from redwood deck
Old 09-20-10, 11:39 AM
Smile remove sealer from redwood deck
Mistakenly, I applied "superdecks composite sealer" to a redwood deck. I should have used an oil sealer. I am trying to remove composite sealer. I tried "Super Decks remover" but it turned the redwood black. Also tried "Super Decks Granular cleaner" which you use with scrub brush.
I have done this 4 times and there is still 50% of composite sealer left on the deck. Any ideas?
Old 09-20-10, 11:44 AM
Received 167 Votes on 148 Posts
Welcome to the forums!
I believe I'd have just let it wear/weather off and then redone it with the correct sealer. Since cleaners aren't removing it, you'll either need to use a chemical stripper of sand it off.
Old 09-20-10, 03:05 PM
Received 62 Votes on 58 Posts
Sounds like a lot of work, I'd leave it and just use the other product next time
