Thru-Bolt Ledger Connection - Bolt Size?
I'm attaching a 2x10 pressure treated ledger to my townhome. I have the lower level ceiling torn out, so I can get to the band joist on the inside of the wall. Because of this, I should be able to use a thru-bolt (instead of lag screw or ledgerlok) connection.
Is 3/8" x 5" long hot dipped galvanized the correct type?
I used 1/2" bolts with fender washers. It's been a while but I think that's what was required by code. I used 2 bolts per joist bay and staggered the bolts so that they didn't weaken the ledger. Make sure they are hot dipped galvanized.
One code change here is the fender type washers are required not only on the nut side, but a size larger is required on the carriage bolt head side. Larger size to allow it to sit flat around the shoulders.
If you plan to keep the place a long time, I'd suggest using inert spacers (4" x 4" blocks of Trex work well) between the ledger board and the house's rim board. Otherwise, there's a good chance the contact surface between the two members will eventually rot out, unless carefully-applied flashing and caulking are used to keep water away from that area. You'll need 6" long bolts if you use 1" spacers.
And never use less than 1/2" galvanized bolts for ledger attachment. I suspect the earlier post saying to use 2 bolts per joist space may be a bit more than needed, but check your local building code requirements to make sure. A single mild steel (Grade 307) bolt has a working shear resistance of almost 1 ton (1963 lb.).
1/2" hot dip galvanized or some other fastener certified to work with modern treated lumber is required here. They will not accept 1/2" zinc plated bolts. Hot dip galvanized is the minimum corrosion protection as is 1/2" diameter. Lag bolts/screws are not permitted. They must be through bolts.
