Can deck post be painted?
Old 05-04-12, 01:46 PM
I have 9 - 6x6 post for my deck plan and they are about 9' high from the ground.
I saw a neighbor's deck and the posts were white. It seems that they used some sort of vinyl sleeves.
So I am just curious if I can paint 6x6 posts to white. Any problem over times?
If I can't, what's the benefit using the vinyl sleeve beside clean look?
Vinyl Post Sleeve, Deck Post Sleeves, Fence Post Sleeves
Thank you,
Old 05-04-12, 01:51 PM
Received 676 Votes on 598 Posts
Vinyl sleeve basically means no maintenance other than cleaning
I've painted a lot of deck posts/rails over the years. Aside from a little more prep needed when it's time to recoat - it's not a big deal. If the PT is fresh, I'd recommend using a white latex solid stain rather than primer and paint.
Old 05-04-12, 01:56 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Be aware, the posts will "check", so the cracks will become obvious. If that's not a problem, then paint would work.
Old 05-04-12, 02:34 PM
Thank you for the comments,
marksr, do you have any particular brand that you recommend for "white latex solid stain"? Thanks again,
Old 05-05-12, 03:36 AM
Most any brand should do ok. I mostly use SWP coatings but that's mainly because they have more stores and better hours than the other major paint brands in my area. I tend to shy away from the big box paint depts because they generally stock coatings based on low price rather than quality.
Old 05-07-12, 06:52 AM
Received 1,165 Votes on 1,123 Posts
Sherwin Williams and Benjamin Moore paints tend to get the most recommendation here.
Keep in mind every manufacturer makes a cheap line of paint you want to avoid.
