Patio Post Spacing
Old 05-14-12, 09:29 AM
P
Patio Post Spacing
I am attempting to build a covered patio. My question is, if I use 4x6 post for the corners and 2 4x6 posts in the middle at 11' apart, would that be suffice for a patio 33' long?
Old 05-14-12, 01:07 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums! What are you using as framing for the cover? 2x4, 2x6, etc. The spacing may not be too great for the proper wood size. Otherwise I would space them at 8' intervals.
Old 05-14-12, 06:09 PM
P
Thanks for the reply. I will be using 2x6 for the patio cover @ 16" apart. The support beams attached to the house and edge of patio will also be 2x6's. I can't remember where I found that i could use a max of 12' between post using 4x6. Would that be correct?
Old 05-15-12, 03:32 AM
chandler's Avatar
Investigate this: Maximum Span Calculator for Joists & Rafters
It will help in your span calculations. 2x6 won't span 12'.
Old 05-15-12, 10:31 PM
BridgeMan45's Avatar
Received 2 Upvotes on 2 Posts
Might want to check with the AHJ first (building department people). They have to give their blessings to whatever you build. FWIW, you should consider using all 6 x 6 posts, in compliance with the IRC. The Code also has beam and joist span criteria for decks that are worth noting.
