Pergola Posts
Received 0 Votes
Pergola Posts
Planning on building a pergola and will hang a hammock from opposing posts. I've looked at lots of pergola plans and have seen two ways of doing the posts: a) dig holes put in the posts and fill with concrete or b) dig holes fill with concrete put those metal post bases in the concrete.
Oh - and I'm planning on using 8 X8 posts.
Any thoughts on which is the better idea?
Sonotubes are a great way to save on forming time/materials, and don't have to extend all the way down into the hole. I like using 1' long sections, suspended over the hole using 2 x 4 cross-braces, and extending 6" above the ground line. You should just call your local building department to get their footing depth requirements, instead of guessing or assuming.
Not sure I'd want to trust the steel post brackets to prevent the posts from rotating inwards towards each other when repeated lateral loads are placed on them by the hammock connections. Unless you make sure the roof structure can hold the posts plumb without wracking, regardless of how heavy the hammock loads are.
I would not just put a post base that isn't meant for this purpose. I think this base would suffice and would help with horizontal as well as vertical pull out. PB/PBS Regular and Standoff Post Bases
Better for it to get complicated early on than to find out you did it wrong and had to do it over. Twice the labor, twice the materials. We're here. You got back up.
You are right, Bridge, but IMO 6x6's would suffice. 8x8's would build an ark! Doc, trying to bring things into perspective, is there a good reason for 8x8's??
Plain hammock posts, embedded probably would need 8x8's. You are building a structure, right? Are you putting a roof system on it? If you use rafters and collar ties to the structure it will give additional support not afforded by plain posts. I think 6x6's would suffice.
Received 0 Votes
yeah, as soon as I posted my reply that occurred to me. That's gonna save me a bit of money. The plans call for pretty typical stuff up top - double joists or beams (or whatever they're called) that will sandwich the posts, another set of
2Xs crossing them and smaller pieces on top of them. Thinking about getting some sun shade material that'll run on on cables. Again, ambitious plans for someone whose never built something like this but has SEEN lots built on TV
Received 0 Votes
Marksr - I have relied on you folks for expert advice for years and years; I have yet to be steered wrong. When we finally get around to this project I'm sure I'll be checking in quite often. Thanks in advance!
