Hip roof covered patio
Received 0 Votes
I want to build a roof over my patio and attach it to my existing hip roof, I'm concerned about causing damage to my roof. I have plans and the lumber yard will supply everything that I need in a kit. Could someone advise me on what to do to prevent damage to my roof?
FYI:I don't want to use a contractor cause their prices are ridiculous 10 to 15k on a patio is crazy when the average cost for the buildout should only be about 3k at the most for labor and material.
Welcome to the forums! In all fairness, it would help if you could post a few pictures of the proposed location so we can see what you see. Not real sure how you will attach a concrete patio to a roof, but anything is possible.....I guess. How you support it that far up in the air will be the trick. We'll wait on pix. http://www.doityourself.com/forum/el...your-post.html
Diagram
Is this what you are proposing?(Overhead view)
In this situation, the old roofing is removed where the new structure attaches to the old roof so that the new framing attaches directly to the old roof sheathing. Proper flashing is used in the two valleys when the old and new roofing materials are joined.
The pros will be along shortly to clarify.
