Building covered patio
I'm trying to build a free standing covered patio with a flat roof and need a little help. The attachment called "patio2" is a rough side view of the project. The other picture shows a very incomplete sketch(without roof, not in perspective, etc...) but should give an idea of the overall idea at least.
The boards circled/dotted in red will be 2x10x10ish. The length of the patio will be about 16' and I want the pitch to have a 6" difference, if that makes sense.
According to this: Right Triangle Angle And Side Calculator .. That means the pitch is 1.79 degrees. Is this correct?
Most of these cuts I can make with a cut-off saw, which I own. But I'm thinking I need some of the boards(circled/dotted in red) cut long ways(ripped?) on a table saw at a slight angle so the rafters(?) will have good contact with the supporting boards(joists?).
So my main question is: Will a table saw be able to successfully rip a 2x10x10 at about 1.79 degrees? Are small angles like this easy to do on a table saw?
If this is possible I would definitely have help since I don't know too much about table saws at all.
Thanks for any feedback on this!
Thanks for the replies!
Since I haven't really used a table saw, I just wasn't sure if the blade would be able to be angled like that and at such a tiny amount.
Joe, This will be a freestanding structure and will be sandwiched in between the house and another large brick "shed/shop". I figured it would work better to have the water run in one direction into a gutter away from the existing structures.
Although the pitch I'm using is very small, it is at least more than the minimum for the 16' length, which would be 4"(1:80 or 1/4" per 12").
In your opinion, how much more of a slope should I have and still keep the flat roof look?
