Question about installing cedartone deck boards
Old 05-28-13, 05:51 PM
Hey all, I just finished framing my deck and I'm wondering if I am supposed to leave space between the deck boards when I install them. I've heard everything fom no spacing, to using a 16d nail as a spacer, to 1/8", but I'm not sure which is appropriate for cedartone boards 5/4x6". Thanks for your help/advice!
Old 05-28-13, 06:41 PM
Received 1 Upvote on 1 Post
Ok so whats Cedar tone?
If it's a composite then a 16D will be fine.
Old 05-28-13, 07:26 PM
Received 1,273 Upvotes on 1,213 Posts
No space is a bad idea unless you have the whole thing pitched for water to run off. Even then, I would not go no space. 16D nail is fine by me as well.
Old 05-29-13, 04:11 AM
Received 854 Upvotes on 748 Posts
The 'no space' works well for wet PT wood or fresh cut wood - anything that is wet and will shrink as it dries which then leaves a gap. The decking on my covered porches is sawmill pine/poplar which was installed as tight as I could get it. The gaps range from 3/16"-1/2"
With the exception of T&G, you always want a gap both for drainage and air circulation! The deck will last longer and look better that way as dirt won't accumulate in the cracks.
Old 05-29-13, 12:51 PM
Joe, here's some info on cedar tone lumber https://www.midwestmanufacturing.com...neBrochure.pdf
Would it make sense to leave the same gap between the house and the first deck board?
Thanks for the help guys!
