Washers behind ledger to make it flush?
Old 06-25-13, 08:32 PM
Y
I'm putting up a new deck and a portion of the deck runs attached behind my garage which is resting on a concrete slab. when I look at the location of my ledger - which runs under the garage door - it would rest partially on the garage wall (about 2") and the rest against the slab. the issue is that the wall is has about a 1/4" overhang past the slab so it would cause the ledger to angle out if I secured it.
Is it okay to add a couple of galvanized washers (1/4" worth) to the concrete anchors behind the ledger to make everything flush?
Old 06-25-13, 08:39 PM
Received 1 Upvote on 1 Post
Going to have to post some pictures on that one.
No clue how a ledger can run under a garage door.
Old 06-25-13, 08:49 PM
XSleeper's Avatar
Received 1,946 Upvotes on 1,746 Posts
Heh, me either. But yes, adding the washers as shims should be fine.
Old 06-25-13, 08:57 PM
G
You can use up to 1/2" of washers and meet code minimum, Table 5; http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Non-corrosive, page 5.
Gary
Old 06-26-13, 08:26 AM
Y
garage door...
Sorry, I meant the door at the back of the garage. Not the actual 'garage door'
That would be a hell of a deck...
