Solid Surface Deck Finish
Old 02-23-01, 02:11 PM
G
Guest
I plan to resurfase an existing deck with plywood, making it a solid surface. This will give the deck a more formal appearance and keep the patio below dry.
I've looked at elastomeric materials like Spantex that seal and provide a watertite barrier, but they are quite expensive.
Any alternatives to this??
Old 02-23-01, 03:28 PM
A
You could put fiberglass clothe and resin over the entire surface. Not sure how that would compare cost wise with Spantex.
Old 03-03-01, 08:16 AM
G
Guest
Deck Surface
Two problems with that....the cost would be quite high and it would probably be slippery here in the Northwest, without sand or something on the surface...
