Driveway/Concreate Resurfacing
I recently purchased a home that has a driveway crack that has been filled with an epoxy filling to prevent water from going in and eroding below the concrete.
It's a little unsightly so I'd like to improve the appearance.
I've heard of people putting a new thin layer of cement over the driveway. I assume you cannot just cover the crack but need to resurface the total drive.
Is this correct ? Does it hold up well ?
Any help appreciated.
Thanks
Thanks
polymer-modified cements have been around for a long, LONG time & perform well,,, there are even fed specs + state dot specs written to accommodate the stuff,,, naturally likely permanence is depending on surface prep, product quality, & artisan skills,,, concretenetwork.com is 1 source as is concretelocator.com & decorativeconcreteforum.com [ no $ interest ],,, & no, nothing is uv-proof against fading
our atl d/w was resurfaced 12yrs ago & the only part that's color ( acid-stain'd ) is the throat which gets new coat of sealer each yr - we use ' css ',,, it IS the best sealer outside of polyureas
3,,, & y/w btw, none of those links are for selling specific materials but for educational purposes
