saltillo tile outdoor patio
Old 10-07-14, 06:48 AM
B
I would like to create a saltillo patio outdoors, 9 x 12. I cannot find out what kind of base it needs. Can it go directly over paver base or is it only to cover a pre existing concrete patio?? I live in Florida and I do not think the weather would prevent an outdoor saltillo patio
Old 10-07-14, 09:00 AM
P
Received 787 Votes on 724 Posts
What is "saltillo"? Is that a concrete paver block or is it a porcelain tile?
Old 10-07-14, 09:07 AM
pugsl's Avatar
Received 75 Votes on 68 Posts
I think it's clay tile from Mexico, Put some in a house had in AZ. Don't know if will hold up in Fl. Damp.
Old 10-07-14, 10:46 AM
B
it is clay that has been kiln dried
Old 10-07-14, 12:06 PM
pugsl's Avatar
I personally like it. Are you going to lay it yourself? I did a whole lower floor in AZ with it. remember tile does not have a flat surface. Any furniture will tend to wobble.
Old 10-07-14, 01:35 PM
P
I would think it's porous nation would eventually allow mold, mildew and algae to discolor it. Maybe you could find a porcelain tile that has a similar look.
Old 10-07-14, 04:30 PM
czizzi's Avatar
Received 15 Votes on 13 Posts
Are you considering tile over a compacted paver base? How thick are the tiles? I would assume that unless the Saltillo is an inch thick minimum that a loose lay over base with broom sand fill would not hold up very well.
Old 10-10-14, 04:44 AM
Received 1 Vote on 1 Post
tile needs grout in order to be placed/secured,,, even outside, you need conc 1st,,, IF they're pavers, you can place over well compacted & drain'd gravel base
Old 10-10-14, 07:08 AM
pugsl's Avatar
Saltillo Is a soft clay tile. Kiln hardened, When I installed in AZ inside I used a radial arm saw with a masonry blade. Used in AZ inside and outside but climate very different in Fl. Not perfect squares and 1/2 grout lines.
