Paver Sealer Stripper
Old 10-10-14, 11:57 AM
I applied high gloss Paver Sealer to my brick interlock driveway.
After the first coat dried, I applied a second coat.
Then some parts of driveway has a white film.
How to fix this problem?
I am thinking using a paver sealer stripper to remove the brick interlock driveway.
Which brand is good?
I google and discover this website
www .opwdecks. com / paver-sealer-stripper.htm
Is that a good product?
I live in Canada.
Old 10-10-14, 03:53 PM
Did you use polymeric sand? - Often some white stains can occur.
I assume it is an interlocking paver patio with a brick size paver that is laid in a concrete sand setting bed with sand between the joints to create an interlock.
Dick
Old 10-11-14, 02:18 PM
Yes, my contractor used polymeric sand.
It is an interlocking paver driveway with a brick size paver that is laid in a sand setting bed with sand between the joints to create an interlock.
