Load strength 4x6 posts
Old 12-18-14, 02:33 PM
My dad called and asked me what the load strength of 4- 20" 4x6 posts would be, since I do not know, I figured I would ask here
Thanks
M.C
Old 12-18-14, 02:36 PM
Its a 8x8 deck andthere would be one in every corner
Old 12-18-14, 02:38 PM
chandler's Avatar
Received 3 Votes on 3 Posts
Load in which direction? 4"? 6"? or vertical compression? What is he doing with them?
Edit: your answer came across as I was typing. He would be better off using 6x6 posts for corners of the deck, especially if it is any height off the ground. You are in my old stomping grounds (Forest Park), so it could be low to the ground. We'll need to know that.
Old 12-18-14, 03:12 PM
vertical.. into 2x12s doubled.. held by strong ties post caps
Old 12-18-14, 03:19 PM
chandler's Avatar
Here's a PDF file that I will think your dad should read first. It gives much of the code compliance that he will need, including how to attach his beams to the posts, and how NOT to do certain things. It also tells how to do the footings and post bases, and how NOT to bury the posts. If you have specific questions, fire away. http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
