Waterproof storage under a deck
Old 02-05-15, 01:03 PM
We live on a house built on stilts, by a river. Lots of deck space, all around the house. Standard decking. Maybe a quarter of inch between boards.
I'd like to find a cheap/easy way of making it water proof under the deck. I'd like to convert what was a drainage area into work/stowage, all around. It would have to be something just below the bottom of the deck.
Sure would appreciate whatever you think might work.......
Old 02-05-15, 01:43 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Google "under deck". It will show you the different types of water proofing for under deck installations. Some easy, some not so easy.
Old 02-05-15, 02:14 PM
One possible draw back is the lack of air flow under the deck once that roof goes in.
Lack of air flow can cause molding issues and premature failure of the deck.
Old 02-05-15, 02:17 PM
Received 224 Votes on 206 Posts
Also consider how debris will get out from the space between your deck and roof system. I've seen a couple that were a mess after a few years with leaves and other debris damming up and holding water and insects.
Old 02-05-15, 02:22 PM
chandler's Avatar
Dane is correct. If the slope is not sufficient, water and "stuff" won't be washed out. Just ask one of my clients who had bear poop in theirs. I had to change the slope from 2" in 12' to considerably more. I would not rehang the panels unless the owner cleaned them with a pressure washer.
Old 02-07-15, 03:44 PM
that's a REALLY SMALL BEAR imho so small, in fact, i'm surprised you could even see the scat
Old 02-07-15, 04:27 PM
chandler's Avatar
400# plus her cubs. They crap on the deck and it washes down the cracks to the under deck and just sits there.
