Bluestone Walkway
Bluestone Walkway
Last year I posted here for help with laying a very shot bluestone walkway. I dug out a couple inches down, then poured a coarse gravel & concrete sand on top of that, laid the stone and filled the joints with the sand (watered it in).
That held for a short time, but soon it loosened right up, and after the winter the stones have now all shifted. Before I dig it up and redo it, what did I do wrong the first time?
Thanks for any advice!
I'd bet the problem starts with the base. What exactly is "poured a coarse gravel & concrete sand on top of that"?
Bluestone Walkway
It was last year and I don't remember exactly what size/coarseness I used, but it was probably 2 inches of gravel covered by an inch of concrete sand.
The base is key to everything and involves a base of compacted stone usually at least 4-6" deep then your sand layer. The more harsh the climate or application the more I like to go thicker on the base. Next to that compaction, and doing it properly, is key especially with a thicker base.
