Rusted Metal Stair Restoration
Old 05-26-15, 07:29 AM
Hello DIY forums. I need to know the best inexpensive way to restore the metal stairs that lead to my backyard. The paint and metal are chipping pretty badly and I think it would be a bad idea to just paint over it. How should I prep it? (Sand?, scrape?) Should I use a primer after prepping? What kind of primer should I use? What kind paint should I use after that?
Sorry for my ignorance and all the questions. I just want to do this the right way so it won't happen again. Thanks.
Old 05-26-15, 07:32 AM
Norm201's Avatar
Received 73 Votes on 68 Posts
Can you include a few pics? Take one from a distance and another close up.
Old 05-26-15, 08:02 AM
Idk how to upload pics to here but heres the link to the pics in my google drive. https://drive.google.com/folder/d/0B...MzTFBoakE/edit
http://www.doityourself.com/forum/li...rt-images.html
Old 05-26-15, 08:12 AM
Norm201's Avatar
The experts will be along shortly, but yes I think a good scrapping (sandblasting would be in order. Then a good high end primer. Followed by your color of your choice. Is this domestic to US or are you non-US?
Old 05-26-15, 08:25 AM
Thanks. I'm US, specifically new york.
Old 05-26-15, 09:49 AM
Received 131 Votes on 117 Posts
Ideally sandblasting or otherwise getting back to shiny metal is best ..... but maybe too expensive
I'd use a wire cup on a grinder and clean the best I could then apply a coat of a rust inhibitive oil base primer followed by 1-2 coats of oil base finish paint. If for some reason you need/want to use latex for the top coat - apply 2 coats of primer!
Old 05-26-15, 11:44 AM
Thank for the advice!
How about this for the primer?
Rust-Oleum Stops Rust 1-qt. Flat Rusty Metal Primer-7769502 - The Home Depot
A finish paint similar to this?
Glidden 1-qt. Just Teal Interior/Exterior Oil Paint-GL 310 04 - The Home Depot
Any significant advantages latex has over oil based?
Old 05-26-15, 11:52 AM
Should do fine ...... but you'll need more than a quart of each
The only advantage that latex has [other than quick dry and easy clean up] is it's less likely to fade in the sunlight. Given a choice, I'd use oil base.
Old 05-26-15, 01:23 PM
czizzi's Avatar
Received 9 Votes on 7 Posts
If it was me, I would first treat the rust after scraping with Ospho Ospho Rust Treatment - Since 1947 Ospho changes the chemical makeup of the rust and preps it to receive the top coating. Ospho used to be sold by Duron, which was bought out by Sherwin Williams - so that is where to begin your search. I think that if you do not treat the rust now, it will just bleed back through in time.
I would then use a direct to metal coating such as Devflex https://www.norkan.com/pdfmanuals/De...ex-4206-qd.pdf It dries exceptionally hard and I use it to paint metal stair railings at a local hotel as well as the exterior room doors that get lots of sun exposure. Previous oil based paints faded and got hazy, I painted the doors with Devflex 4 years ago and they still look great. Devflex is purchased at a PPG/Glidden Professional store - Formerly call Dulux Paints.
Old 05-27-15, 05:32 AM
Thanks for all the advice guys. I think I got this now. I'll do the project and update you guys over the weekend after I'm done.
