Mounting post brackets
Old 06-02-15, 05:25 AM
I am mounting 6 6x6 posts on an existing concrete slab. My problem is that the slab has a slight slope to it. Can anyone tell me how to get the post plumb? Do I trim the posts bottom to fit the slope (it is not much slope) or can I shim under the brackets them selves? They are Simpson abu66rz brackets. Thanks for your advice.
Old 06-02-15, 05:50 AM
Temporarily Suspended
The posts are supposed to be mounted on footings, if you want to comply to code. If you still want to set them on the slab, I guess that you can cut the angle. I've never done it. What are you building?
Old 06-02-15, 06:57 AM
czizzi's Avatar
Received 9 Votes on 7 Posts
Pulpo is correct, you need a footer to support either posts for a deck or other structure. The slab will only be a couple of inches thick. Here are the national guidelines for building decks. http://www.awc.org/publications/DCA/DCA6/DCA6-12.pdf
Old 06-02-15, 08:07 AM
I am building a cover over an existing patio. Kinda like a pergola only with a metal roof on it.
Old 06-02-15, 01:07 PM
Even though there may not be a frost line in Texas, the code still may require a 2' footing below the slab, under each post. It will solve your slope problem & provide compliance with the code.
Old 06-02-15, 02:52 PM
When I got my permit, the guy said it would be fine to bolt it to the slab.
Old 06-02-15, 04:47 PM
That's strange. Maybe Texas has different codes. A NY inspector would never say that.
