Flashing ledger
Old 07-16-15, 06:43 AM
Flashing ledger
Deck was covered with 3/4 inch plywood and dura deck (vinyl) over 12 years ago. Am switching to composite. Removed all plywood and discovered the flashing or lack of at ledger. Joists are perfect as dura deck was nailed to wall one inch above ledger. Can I just run done butyl flashing tape on walk plywood under house wrap and over ledger. I am installing "rain escape" after and will run that up over ledger as well.
Old 07-19-15, 11:09 PM
BridgeMan45's Avatar
How does "run done" butyl flashing tape work? I've never heard of the term.
Whatever you do, don't build a flashing dam that will pond water between the house and the first deck board. Instant recipe for failure.
Old 07-19-15, 11:14 PM
XSleeper's Avatar
Received 299 Votes on 272 Posts
Flashing tape is not meant to be used in place of metal flashing. You should use a metal flashing over the ledger and tuck it under the housewrap. Make sure you aren't using aluminum flashing over treated wood.
Old 07-19-15, 11:28 PM
can someone please tell me how to post?
I read through the info, it says there is a link to post a question to a forum, but there is no link. I've been searching for a way to post a question for 1/2 hour, no luck. ANYONE HELP?!?!?!
Old 07-20-15, 04:09 AM
chandler's Avatar
Received 3 Votes on 3 Posts
Alexa, welcome to the forums! When you click on the forum to which you want to post, look at the top left of the page in the Yellow circle. You will see Post to New Thread. Click it and go for it.
