Power washing a really dirty deck
Old 07-19-15, 01:27 PM
Geochurchi's Avatar
Received 21 Votes on 21 Posts
Hi All, looking for suggestions on products to clean a really moldy looking composite deck,it's surface is kind of Grooved not really smooth.
Thanks
Geo
Old 07-19-15, 01:35 PM
Geochurchi's Avatar
Sorry, have this question in the wrong post.
Geo
Old 07-19-15, 08:54 PM
Received 475 Votes on 445 Posts
No problem Geo..... now you've got your own thread.
Old 07-20-15, 05:40 AM
Norm201's Avatar
Received 106 Votes on 97 Posts
Use any of the deck washes available in most stores. Follow direction exactly. You may need to do it twice. If you use a power washer do not be too aggressive with the nozzle setting. You can raise the grain to a point that sanding will be needed.
Old 07-20-15, 06:20 AM
Received 153 Votes on 136 Posts
Personally I don't bother with the commercially prepared deck cleaners although they are diy friendly. I always use a bleach/water solution [never stronger than 50%!] add TSP when needed. It's cheap and effective! While a pressure washer makes the job easier, a garden hose will also do a good job.
Both too strong or close with the PWer or too strong a bleach solution will damage the wood necessitating sanding
