Tall deck sway
Old 08-18-15, 08:00 PM
Tall deck sway
Recently completed the construction of 25 x 30 boat house with a flat roof / deck built on an existing dock. The structure is 11 feet high and sits on steel I beams with 14 - 6x6 posts. My issue is that the deck has a slight sway that I am looking to eliminate or reduce. I have installed 6x6 cross bracing on most posts and have reinforced the I beam to eliminate movement at the foundation. Despite a stable foundation and cross bracing the 6x6's are flexing. Due to access I can not cross brace to the bottom of the posts. My thoughts are to reinforce the 6x6's with aluminum C channel to stiffin the 6x6's. Has anyone had this experience and are there other suggestion?
Separated from... http://www.doityourself.com/forum/de...long-deck.html
Old 08-18-15, 08:27 PM
Received 378 Votes on 355 Posts
Welcome to the forums neighbor !
I started a new thread for you. The other one is already too long and not really directly related to your problem.
I don't have an answer off the top of my head but I can tell you that pictures are a big help.
http://www.doityourself.com/forum/el...rt-images.html
Old 08-19-15, 04:30 AM
chandler's Avatar
Received 2 Votes on 2 Posts
Are your posts firmly attached to concrete footings? Being associated with a dock, I have my reservations. Maybe you could post a few pictures so we can see what you see. http://www.doityourself.com/forum/el...your-post.html
