Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Decks, Patios, Porches, Walkways, Driveways, Stairs, Steps and Docks
Reload this Page >
Crack between concrete patio step and patio door, leaks down basement interior w
Old 09-16-15, 04:08 PM
Question Crack between concrete patio step and patio door, leaks down basement interior w
Hello! I have discovered (by getting a wet basement wall and pile of water) that when it rains there is a crack on my back patio between the concrete step up to the patio door and the door itself. Suggestions on repairs? Total beginner here and wondering if a sealant or something could fix this simply? Thanks for any advice!!
pic is of basement wall. wont let me up load the pic of the step
Old 09-16-15, 04:45 PM
Temporarily Suspended
Use photobucket.com to post the pic of the stoop. What's inside doesn't matter.
XSleeper's Avatar
Received 303 Votes on 276 Posts
Concrete does not form a continuous barrier to water, and it needs control (expansion) joints. I would imagine that the area you are referring to should have an expansion joint and some sealant.
Old 09-16-15, 05:19 PM
Old 09-16-15, 05:29 PM
Actually, we could use a wide angled pic. Step back & take a pic of the entire stoop.
Old 09-16-15, 05:42 PM
more pics
http://s556.photobucket.com/user/Nic...%20Step%20pics
more pics of the step, from a farther away stance
Old 09-16-15, 07:27 PM
I think that you can easily seal that step. Chop out whatever is loose. The space between the step & the door can be sealed with an exterior caulking. Unfortunately, I don't remember the product that Stadry recommended in previous posts. A mortar mix can be used to seal the rest of the step. I use a Type S mortar mix, with a bonding agent.
Stadry, concretemasonry or bridgman45 may have other suggestions.
