2x deck boards - nails rusting
Old 12-20-15, 07:08 AM
I have a small cantilevered deck with floor planks made of 2x6 (PT?) boards. Deck extends about 4' off the house, like a balcony. About 20 years old. Boards are in good shape - no rot - but are checkering in places and as a result the nails are rusting big time, heads are about gone and blistering the paint up. I would like to replace them with deck screws before repainting but of course I can't pull the nails. Should I just fill over the nails and place screws next to them, or is there a way to get rid of the nails?
Old 12-20-15, 07:10 AM
chandler's Avatar
Received 2 Votes on 2 Posts
If non HDG nails were used, they will consume themselves eventually. I would just use 3" Decking torx screws beside the nail location. Even if you removed the nails, you would not want to use the same hole for your screw.
Old 12-20-15, 09:48 AM
Thanks. Any way to stop the nails from rusting further?
Old 12-20-15, 11:38 AM
chandler's Avatar
Not that I am aware of. They are rusting throughout their entire length, so even if you dipped a Q-tip in paint, the paint would fail in short order.
Old 12-20-15, 03:34 PM
Received 132 Votes on 118 Posts
What type of coating do you intend to use on the deck? Generally the best way to address non galvanized nail heads is to countersink them and then putty up the hole. The putty normally stops any rust from migrating to the finish.
