Concrete patio/planter filled?
Old 03-28-16, 12:07 PM
Hello all,
I am wanting to fill in this patio/planter with concrete and create a uniform look to where the outer edge isn't noticeable. Will I need mesh/rebar when I fill in? I have never done any concrete work but want to tackle this soon. Thanks!
sorry about the sideways pic
Old 03-28-16, 12:38 PM
BridgeMan45's Avatar
Filling the inside with concrete will do nothing to change the appearance of the outer edges.
Old 03-28-16, 12:43 PM
well I didn't want the edges to stand out, old with new-any ideas? Will I need to add an expansion joint to the edge?
Old 03-28-16, 05:28 PM
Received 42 Votes on 37 Posts
If you really want to fill that in with concrete all that old top soil needs to come out to a bare minimum of 8" and be back filled in layers with compactable fill, compacted with a plate compactor to a minimum of 3" of the curbing.
Expansion strip against the brick.
Going get to hit with a small load delivery charge if you have a truck deliver it and end up with a useless small patio and still have that curb show.
Old 03-28-16, 07:07 PM
So essentially 3" thick of concrete? I was hoping to get a mixer and mix myself, do I need to use mesh or rebar?
Old 03-28-16, 07:10 PM
Oh and what type of concrete should I use?
Old 03-29-16, 04:12 AM
Received 166 Votes on 147 Posts
If mixing it yourself you'd use something like this - Shop QUIKRETE 80-lb Gray High Strength Concrete Mix at Lowes.com
or have to buy sand, gravel and portland cement so you can mix it from scratch.
Old 03-29-16, 01:26 PM
thanks!
Old 03-29-16, 02:47 PM
Received 23 Votes on 22 Posts
"or have to buy sand, gravel and portland cement so you can mix it from scratch. "
Ah, the bad old days. Does anybody do that anymore?
Old 04-05-16, 02:59 PM
all of the above depends on the temperature of your 'where' - do you get occasional freezing temps ? i wouldn't go thru all the steps joe outlines in so tx or even here in atl
