Mulch driveway to garage?
Old 05-14-16, 01:41 PM
I have a lot of mulch laying around from trees that had their stumps ground.
I also had a metal garage put up recently with a concrete slab floor.
There is an area which is about 15 feet by 20 feet with grass.
I just put down a weed barrier and would like to use the mulch that I have laying around to make a small driveway.
My concern is wood being dragged into the garage and getting splinters when I am working on the concrete floor. I am also worried about getting tiny holes in tires causing slow leaks that the typical tire shop will never ever find.
I don't care about how it looks and I am not overly worried about it lasting forever.
Thoughts?
Thanks
Old 05-14-16, 01:44 PM
pugsl's Avatar
Received 75 Votes on 68 Posts
It would take a solid branch to puncher your tire, I would not worry about that. Can't sat about splinters being dragged in.
Old 05-14-16, 01:45 PM
Received 97 Votes on 85 Posts
IMO, you don't have mulch on your hands, you have garbage. I would dump it in an inconspicuous spot on your lot (if you have one) and let it rot.
Old 05-14-16, 01:48 PM
One man's trash is another man's treasure then.
I like how it looks.
My local rock seller is only open M-F, who has time to take off of work to get gravel.
I could go to Lowes and get bags, but whatever I get won't match the crush and run in the rest of the driveway.
Home Depot is way too far.
Old 05-14-16, 03:28 PM
Received 361 Votes on 318 Posts
I wouldn't worry much about splinters from the mulch, generally it won't be dry/brittle enough for that to be a concern. It will take a broom to get the tracked in mulch out of the garage, I doubt you could do anything outside to prevent it from getting tracked in.
Old 05-14-16, 04:56 PM
Received 83 Votes on 78 Posts
Weeds and grass will just grow right through weed block and be harder to pull out later.
Should have gotten rid of all the top soil laid drive way cloth then had the crush and run.
Using mulch for a driveway would be the last thing I would have used, it's just going to rot and make a great place for weeds to grow.
Old 05-15-16, 06:26 AM
P
Received 747 Votes on 686 Posts
Don't do it! I have a series of trails on my property and some are graveled like a driveway. Years ago I had an unlimited supply of mulch and mulched the trails. It looked great and worked great for a couple years. By year three the problem started to appear. Mulch decomposes and turns to mush. Eventually I had to come back and remove all the decomposed mulch because it became such a mushy mess.
