Is it possible to find this type of spindle anymore?
Old 06-11-16, 06:42 AM
Hi all, I'm replacing the trim on my front steps as some of the spindles and moldings have rotted. I was wondering if it's possible to find this style of spindle anymore so the new stairs will match the rest of the deck.
Thanks!
Old 06-11-16, 03:46 PM
Received 42 Votes on 37 Posts
With a location in your profile someone just may be able to suggest some places to look.
The reason they rotted may be because they where not pressure treated or made of a rot resistant wood.
I'd be going some old time real lumber yards not a box store.
A simple trick to painting them is to screw in a cup hook in one end.
Use a piece of gutter as your paint pan and just dip them in and hang from a make shift clothes line.
The only drip will be on the bottom that can be sanded off.
Old 06-11-16, 04:31 PM
XSleeper's Avatar
Received 298 Votes on 271 Posts
I threw several of them away a few weeks ago as part of a bathroom remodel. They were butt ugly and had to go. Doubt you will find a match, these were original to this house from the early 60's, afaik.Name:  20160304_095823.jpg
Your best bet is probably to just replace them all so they match, or else steal some from an inconspicuous spot to use elsewhere.
Old 06-11-16, 06:01 PM
Received 1 Vote on 1 Post
With that one as a template, someone with a wood lathe should be able to make you up a batch.
Old 06-12-16, 02:10 AM
BridgeMan45's Avatar
And for only a few hundred bucks, each. Is having ugly really worth that much?
Old 06-12-16, 07:03 AM
Received 23 Votes on 22 Posts
Add my vote to the ugly total. I would just replace them all. Big boxes sell PT turned spindles for a couple of bucks each.
Old 06-12-16, 07:05 AM
Received 166 Votes on 147 Posts
Depending on where and how bad the damage is you might be able to repair them. If you go with replacement and don't want to replace balusters on the porch, I'd go with the cheap straight [non turned] balusters as it shouldn't highlight the difference between the 2 styles.
btw - welcome to the forums!
Old 06-12-16, 07:22 AM
chandler's Avatar
Received 3 Votes on 3 Posts
I did a Google type search and turned up (no pun intended) a manufacturer of spindleswho custom make them as well. I am sure there is a setup and minimun charge, so it may be cost prohibitive.
