Installing Pergola support beams
Old 07-08-16, 07:00 AM
O
Looking at building a 20' x 12' pergola, I'd like your opinion: When my 10' horizontal support beams meet at the midway (6 x 6) post, there's only half of the width of that post to share with each horizontal support beam ... and not enough area (IMO) for proper use of lag screws. Would it be a better plan to notch all my 6 x 6 posts in order for the horizontal support beams to have a platform on which to rest?
Old 07-08-16, 07:40 AM
Received 94 Votes on 83 Posts
I'm missing something - how does notching the 6x6 make more area for the beam to sit on?
Old 07-08-16, 12:31 PM
W
Received 17 Votes on 16 Posts
Fastening Beams
I think the OP's first option is lagging the beams to the face of the post. We know this is not legal or recommended.
Notching would give more support. Someone will follow with code specifics on this.
Old 07-08-16, 12:39 PM
That makes sense - I thought we were talking about resting on top, then resting on the cut edge after notching....
Old 07-08-16, 03:07 PM
Received 75 Votes on 70 Posts
Check out your local real lumber yards, I know mine carry's up to 20' long pressure treated 2 X's.
The 2 X 6's need to be notched.
Old 07-09-16, 05:40 AM
W
2x's
Old 07-09-16, 03:13 PM
BridgeMan45's Avatar
Received 1 Vote on 1 Post
Don't notch anything. Far more effective to just use a short, thick "spreader" beam (3'+/- long) on top of the center post, making a support platform for the beam ends to rest on.
Old 07-11-16, 12:06 PM
A
Do you mean adding something like a jack stud along side the post to rest the 2X beam onto?
Old 07-12-16, 01:41 AM
No. I mean making a capital "T" with the spreader beam on top of the existing column; obviously, the column will have to be shortened by the thickness of the spreader. It (the spreader) has to be thick enough to resist the shear forces it will be subject to, meaning something like a 6 x 6, 3' long. I haven't crunched the numbers, but I don't think a 2 x 6 would work, being too thin.
I'm a licensed professional engineer, but only licensed in Colorado at the present time. That's why I'm reluctant to perform engineering calculations for anyone from another state.
