Older deck at cottage
Old 07-26-16, 03:23 AM
H
I have some work to do on a older deck, replace some boards and then paint or stain. Which brings me to my questions. If I'm replacing a few boards do I have to wait for them to season before staining or painting them?
if so then how long?
On a older deck, about 9 years, pressure treated wood that has never been coated with anything what is better to use Tinted water seal, stain, or paint?
thanks.
Old 07-26-16, 03:46 AM
Received 427 Votes on 382 Posts
Yes, the PT boards need to dry out before you apply any coating. Have you cleaned the existing wood yet?
Clear sealers like Thompson's WaterSeal have a very short life. I don't know how well TWS's tinted stains hold up. Sounds like you may have 2 choices of the type of stain to use; semi-transparent or solid stain. Make sure they are deck stains! There will be some color variation between the new and old boards with semi-transparent, a 'texture' difference will be noticeable if using a solid deck stain. But it will still look nicer than it does now
If you post a few pics we can give better advice pertaining to your deck.
Old 07-26-16, 06:27 AM
H
I shall try and post some pic when I can.
How long should new deck boards weather before staining them?
Do I have use end cut preservative if I'm going to stain them?
Old 07-26-16, 08:44 AM
The end cut preservative is a good idea although many [maybe most] don't bother and theirs seems to hold up fine.
A lot depends on how wet/dry the PT wood is when it's installed. It could be as little as 6 weeks or could take 5-6 months. The more sun/wind the deck gets the quicker it will dry out.
