Driveway gate
Old 07-28-16, 12:30 PM
T
Driveway gate
Hi all,
I'm building a driveway gate. one side will be a small 1 meter gate, no problems there. The other side will be a 2,6 meter gate.
The gate is only 80 cm high, but it is made of hardwood and I will attache a steel frame to the back to help it to keep its propper shape. I will also try to put a wheel under it to help carry the weight. I will bolt the hinges to the steel frame.
My question: what size should my post be, and how deep should I dig/cement it in?
Any suggestions are apreciated!
Thanks,
Thijs
Old 07-28-16, 02:37 PM
W
Received 51 Votes on 46 Posts
Gate
Describe the soil conditions at the gate location.
Old 07-28-16, 02:46 PM
T
Edge where driveway and road join. Both driveway and road have concrete cobblestones, on top of a 15cm sand/concrete mixture. Below that is just eart, packt tightly with some building rubble mixed in.
(Excuse my flawed English)
Old 07-28-16, 04:19 PM
P
Received 1,560 Votes on 1,403 Posts
Would you happen to be from Giessen, Netherlands?
Typically I would recommend burying 1/3 of the post in the ground but in your case I would go at least 60cm but 80cm would be better. I would use a treated timber about 15cm. 10cm is probably more commonly available but I like the "chunky" look of a good strong post.
Old 07-29-16, 08:01 AM
T
Antwerp
Thanks for the feedback. I was thinking of going with hardwood (Azobe). Are wheels a must, or do you think it is possible without?
Old 07-29-16, 08:55 AM
P
You can always try without a wheel. If it starts to sag you can add a wheel later.
