Water pouring into my sunroom
Old 08-25-16, 06:47 AM
F
I installed a patio and had water pouring into my sunroom on the first rainfall. The patio is level with the sill. I installed a new sill and removed two stones in front of the door. I used silicone on the sill inside and outside. I put stones back in and covered the silicone with polymeric sand.
Will this hold ? I don't want another flood. I use indoor outdoor clear silicone.
Thanks not so fun , fundad
Old 08-25-16, 06:59 AM
Received 319 Votes on 283 Posts
Welcome to the forums!
Silicone might do the trick, is the sill the only place water is getting in? why is water getting to that point? is regrading or piping the gutter away needed? pics could be helpful - http://www.doityourself.com/forum/el...-pictures.html
Old 08-25-16, 08:35 AM
Shadeladie's Avatar
Super Moderator
Received 119 Votes on 94 Posts
Curious as to what all the <div>'s mean.
Old 08-25-16, 09:59 AM
P
Received 624 Votes on 577 Posts
Where exactly is the water entering?
Usually you don't want a patio level with the door sill. You usually want some step even if it's a 1/2"-1" to act as a natural dam to stop water. With a patio level with the sill you may have trouble keeping water out as the door's weatherstripping is now being asked to keep water out.
Old 08-25-16, 10:33 AM
F
The water was going under the door sill. I bought a better sill and put silicone on the outside and inside. I'm wondering because the silicone is covered by the pollymeric sand if it will continue to hold or deteriorate. The lowest part of the sill is actually 1/8 of an inch below the patio, so I definitely been thinking about that also
Old 08-25-16, 10:37 AM
F
Sorry about <div> by time I was ready to post I had to sign in again and for some strange reason that was just there
Old 08-25-16, 10:39 AM
As long as the what you caulked with silicone was clean/dry, the sand that gets up against it afterwards won't hurt it much other than looks.
Old 08-25-16, 11:04 AM
F
The silicone is underground the sand is covering it ,you don't see the silicone at all .
That's why I'm wondering I won't see it if it deteriorates
Old 08-25-16, 11:33 AM
You won't see if it deteriorates but that is just a small section of the puzzle - you need to devise a plan that stops the water from getting there in the first place.
Old 08-25-16, 02:59 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
I'd say that is the main problem. It should have been lower than the sill. If you had a contractor do this maybe he needs to tear it out and redo it on his dime.
Old 08-25-16, 03:08 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Ray and Pilot Dane are 100% correct. Should never have made it level, or even with the interior slab. Rookie mistake and I doubt silicone will solve your problem entirely.
