6000 lb Spa on Deck
Old 04-20-01, 04:20 PM
Guest
Question
I have an existing 30 X 12 deck attached to the house about 10" off the ground. Made of 2 X 6 pt lumber. I want to put a spa that will be 64 SF and will have a filled weight of 6000 lbs. I have not pulled the surface boards to check framing as of yet. How do I figure what the load should be prevent future problems. I am thinking of putting concrete blocks under the framing.
Old 04-21-01, 08:59 PM
josh1
hot tub
have u considered having a concrete slab poured and recessing the hot tub into the deck-it wil be hard to work with such limited ground clearance as far as footings and reinforcing goes to put it on the deck
hope this helps---josh
