Riser Material?
Old 10-07-16, 07:12 AM
Riser Material?
Hi, my stringer height is 6-7/8 so I was thinking (hoping) to use 1x8 PT... but nowhere around has any. Regular pine board seems like a bad option for water issues. What is common to use? 5/4 decking?
Thanks.
Old 10-07-16, 07:28 AM
XSleeper's Avatar
Received 298 Votes on 271 Posts
A real lumberyard should have it. if you cant find it, you can use 5/4 decking, ripped on a table saw to half your rise... (3 3/8" or so, maintain a gap between the boards just like you would on your deck or treads).
Old 10-07-16, 08:04 AM
Will do. Thanks.....................
Old 10-07-16, 12:30 PM
Do most people put the riser on the tread or behind it? I prefer the look of the riser behind the tread.
Old 10-07-16, 12:43 PM
XSleeper's Avatar
Behind is best. Generally fastening the back side of the riser to the back edge of the tread (from behind) will result in a stronger stair. Dont know how thick your treads are but the risers could be 2 3/4" and 5 1/2" if you go behind a 1 1/2" thick tread.
Old 10-07-16, 01:10 PM
Treads will just be 5/4 decking. Found the 1x8 PT after all. Didn't think about screwing the riser to the tread but it sounds like a good idea.
