Joist sizing
Old 04-23-01, 06:08 PM
Guest
Cool
I am designing a mezzanine for the space above my workshop in the garage. I plan on using this space for wood/lumber storage and other miscelaneous stuff.
Two questions:
1. What would be a typical loading that I should use for the design?
2. Once I know the loading, how do I go about sizing the joists?
The mezz will be 14' long X 10' wide. The joists will run in the 14' direction with no support column. What size joists are required for a 14' span? Is there a website with an online calculator or chart that I could use?
Thank you.
Old 04-24-01, 09:27 AM
George's Avatar
Tom:
This site should give you most, if not all, the information you need...
http://www.umass.edu/bmatwt/span_tables.html
Old 04-25-01, 09:09 AM
Guest
My guess is that a #2 2x10 is going to be what you will use. Because of the additional load you might want to use 11 7/8" I-joist on 16" centers and call it good.
