Go Back  DoItYourself.com Community Forums > Exterior Improvement Center > Decks, Patios, Porches, Walkways, Driveways, Stairs, Steps and Docks
Reload this Page >
Do I need to pressure wash my new deck build in September before sealing?
Old 04-01-17, 06:01 AM
A
I have a new deck, built in September, it's ready to be sealed. Do I need to pressure wash it first or can I just hose it off with some cleaner, as there are a few spots that are dirty?
Old 04-01-17, 07:22 AM
C
Received 2 Votes on 2 Posts
What material is the deck? .
Old 04-01-17, 11:03 AM
Received 398 Votes on 354 Posts
Assuming it's a PT pine deck it's best to wash it first. It doesn't have to be pressure washed. The main thing is to get any dirt/grime removed along with any mill glazing. This also assumes the wood has had time to dry from the PT process.
Old 04-08-17, 04:59 PM
pgtek's Avatar
Received 1 Vote on 1 Post
Hi
if pt i would wait 1 yr before stain clean it with deck wash and let dry then stain
Old 04-09-17, 03:08 AM
It should be fine to stain a PT deck built in Sept. It generally takes 6 weeks to 6 months for the lumber to dry out from the PT process - depending on how wet it was when installed and the environment it's exposed to.
Old 04-09-17, 05:29 AM
Marq1's Avatar
Received 488 Votes on 452 Posts
Pressure washing a wood deck if done wrong can damage the board, since the deck is new a good cleaning is probable all that is needed.
Personally I use Olympic deck cleaner (Lowes) on my composite deck, have tried others but this has always given me the best results.
A good stain is Sikkens, a bit pricey but lasts a long time!.
