Deck Posts on Existing Concrete Patio Slab
Old 07-12-17, 10:52 AM
R
Installing a 13' l x 12' w x 2' h deck. 6 deck posts will be installed on concrete footings and piers, while the remaining 4 posts would be anchored to an existing 4" think concrete patio slab. Only 3' of the deck will hang over this slab. First, is this allowable or must the slab be removed so footings and piers can be installed? Also, can an expanding foam alternative such as Sika or other backfill brands be used in place of concrete for the posts installed in soil?
Old 07-12-17, 11:09 AM
Received 317 Votes on 281 Posts
Does the slab have a footer that goes down to the frost line? if not, that section of the deck would be subject to movement with the freeze/thaw cycles.
Old 07-12-17, 11:31 AM
R
It does not appear to have a footer from what I can tell. The slab is at least 6 years old and in great condition. Is there a way I might be able to determine whether it has footings or not?
Old 07-12-17, 11:42 AM
You should be able to see if the post go below the slab. Post some pics, if you can't tell. If there are no footings, put some temporary posts on the slab & dig under the original posts. Pour new footings. That will keep the deck up to code.
Old 07-12-17, 12:07 PM
R
There are no posts currently above the slab, so I am assuming there is nothing below. When I removed the preexisting deck (which butted right up against the patio slab) I was able to see the side of the 4" slab, which I was able to measure, but I do not see anything underneath the slab from the one side I can currently see.
Old 07-12-17, 12:16 PM
I read your first post again. Anchoring posts to a slab is no longer code. All posts must have footings. The slab doesn't have to be removed to install footings. You can install footings through the slab.
Old 07-12-17, 12:18 PM
R
Thank you ShortyLong! In regards to using an expanding foam product for backfill as opposed to concrete when setting posts, do you know if this is allowed?
Old 07-12-17, 12:50 PM
I'm not sure how an expanding foam product would be used in that scenario. In all the decks that I've built as part of a crew or alone, we never did that. Dig a hole to the frost line, insert a sonotube & fill it with concrete, concave on top to stop the collection of water. While the concrete is wet, set the bracket for the post or for the beams depending on your design. Let the bracket set with the concrete. Maybe a bracket isn't needed at all, again depending on the design. The following day you can continue the build. If that isn't clear, let me know.
Old 07-12-17, 12:53 PM
Handyone's Avatar
Here are the requirements in my area. Be advised this is for a lightweight patio cover, not a deck, but you still have live and dead loads.
D. Patio cover posts and/or columns may be supported on slabs (minimum 3 1/2” thickness) of not less than 2,500 psi compressive strength, anchored with standard approved post base, installed per manufacturer’s installation instructions.
Pad footings are not required when the total load (live plus dead) does not exceed 750 pounds.
I would consult an architect, they could figure this quickly and it shouldn't cost much.
There also might be a member here that already knows what the live and dead loads are on a 13x12 deck.
