Is PT still good after ripping it?
Old 08-24-17, 01:36 PM
T
I am building a raised bed garden out of pressure treated 2x12s. I want to anchor the corners with some 2x2s driven into the ground. The only ones I can find are not rated for ground contact. I can ripe some leftover 2x12s and make them, but I am concerned that the exposed interiors are not resistant. Is it?
Since the amount I need is so small, I can make the anchors out of either african mahogany or white oak. Would either be adequate for ground contact?
Old 08-24-17, 01:42 PM
Received 854 Upvotes on 748 Posts
Are your 2x12s rated for ground contact? if so they'd be better than 2xs that aren't. Rebar would be another option.
Old 08-24-17, 01:51 PM
Marq1's Avatar
Received 1,210 Upvotes on 1,098 Posts
Its all good for ground contact but just a question of how long it will be around for,
Personally Id install some 4x4 posts in the corners and then you know you will be good!
Old 08-24-17, 02:05 PM
T
Yes, the 2x12 are rated for in ground. I just wasn't sure if exposing the interior reduces that. Certainly cheaper than buying anything.
Old 08-24-17, 02:10 PM
Gunguy45's Avatar
Super Moderator
Received 7 Upvotes on 7 Posts
You could also soak them in the solution "Copper Green" after ripping. I've had very good luck with that. Seems to work very well.
Old 08-24-17, 02:55 PM
Received 1,273 Upvotes on 1,213 Posts
Vic proposed what I would have....
