Notch pergola beam or rafter?
Hello!
I am building a pergola and half the plans I see call for noticing the main support beam ( a 2x10 in my case) and half call for noticing the rafters (2x6s).
I have checked local building codes and it doesn't specify anything for a pergola or patio cover. Is there a preferred method? There won't be much of a load on top but I potentially could mount a TV on one side later. Let me know if anyone has insight! Thanks
Pretty hard to envision what you are doing, or what kind and size of notch you are making, but if you are talking about a ridge beam, and the rafters will set on top of the beam, you generally cut a birds mouth in the rafter just like you do when it is sitting on a top plate. You generally never want to notch a beam or header if you can help it as it weakens the entire beam.
If you have a picture or drawing, attach it so we can see what you are talking about.
