Unsupported Exterior Stair Rail
Old 05-15-18, 07:57 AM
G
Gen
Gen is online now
I have a stairway rail supported only by the spindles. Image is attached. (Sorry the image uploaded in a challenging upside down way!)
I figure I need to get a 4 x 4 at each corner. Question is how do I effectively get these anchored into the asphalt driveway below? Will I need to brace them? How? Anything else? Thanks!
Old 05-15-18, 08:53 AM
P
Received 1,627 Likes on 1,461 Posts
I think you will need to dig a post hole trough the asphalt at least for the lower pole. You might be able to attach the upper one to the retaining wall timber with steel brackets.
Old 05-15-18, 10:40 AM
I agree going deep with the 4x4 is best although bolting it to the stringer might be ok.
Old 05-15-18, 08:49 PM
G
Gen
Gen is online now
Moderator, this is very strange. I've tried uploading the picture, both right side up and upside down, and it always posts as upside down....
Old 05-15-18, 08:52 PM
G
Gen
Gen is online now
Thanks. How thick is asphalt usually, and what's the best way to dig it out?
Old 05-15-18, 08:58 PM
czizzi's Avatar
Your concrete pad should be about 4" thick.
Old 05-16-18, 03:29 AM
Asphalt is often only 2"-3" thick but there is usually a gravel or slate rock base at least double that thickness under it.
Old 05-18-18, 02:49 AM
D
+1
I have the same issue, my deck stairs doesn't seem to have the proper support. The posts were not installed properly (a hole dug and filled with cement). i would be interested in the response. I wonder if I should start a new post..
