French drain exit pipe size
Old 07-22-18, 05:05 PM
W
I am putting a French drain at the front of a storage shed. The exit pipe will be approximately 15 ft. The French drain has a 3" opening, but with an adapter can accommodate a 4" pipe. The opening is still 3". In this case any reason to go with a 4" pipe?
Old 07-22-18, 10:43 PM
Received 129 Upvotes on 114 Posts
Nope, not going to do a bit of good.
Old 07-23-18, 05:14 AM
P
Received 2,309 Upvotes on 2,054 Posts
They offer the option of using 4" pipe because that is the most common size of corrugated black pipe. Many places that's the only size they stock. So while it may not help with drainage it might be all you can find in the big box home center.
Old 08-04-18, 03:35 PM
Received 1 Upvote on 1 Post
i'm w/joe however we never use corrugated pipe for either gravity OR forced drains - only smooth pvc
